So the dilema is how can you trick the ELD into thinking the truck is moving with a Mech. engine that has a elec. odometer, the ECM gets a signal from the output shaft which in turn sends it to the ELD, could you not figure out what signal comes out of ECM that is the odometer and send it to the  ELD and trick the ELD ???  Don't bother with the ELD BS, they work,  just want to use some of the older equipment and with elec. odo. you would think tricking ELD could happen.
