Question
4 answers to this question
  • 0
The AI is a reliable engine. A AI350 is a good engine for a MR or LE garbage truck.  But for  a CV or CT tri axle maxing out at 80,000 pounds hauling  rock down the highway , the AI 350  HP is weak. A  AMI370 would be the minimum I’d have for real heavy use. Even the AI460 barely get the OK in my experience. Good news is the 350 can get factory bumped up in HP or modded by aftermarket parts to get the power up.
https://www.bigmacktrucks.com/topic/55384-2005-mack-engine/#findComment-413896
  • 0
It’s a concrete boom pump truck, it weighs approximately 58k lbs. it would be mostly city driving, I’m thinking 350hp is not a lot but should be ok for its application. However, I read e few reviews and it mentioned electrical and mechanical problems. Not sure what to make of it. [emoji848]
Sent from my iPhone using Tapatalk
https://www.bigmacktrucks.com/topic/55384-2005-mack-engine/#findComment-413907
Answer this question...
