I have a Unishift  transmission in my B61 that has a split aux case.  I have a Duplex to  install in the truck and was wondering if anyone has done this before.   Im curious if the mounts and bell housing flange are the same and if I can use the air assist clutch that comes with the unishift trans with the duplex.   I also have a doner parts truck  with a triplex in it .  Any comments ???
https://www.bigmacktrucks.com/topic/55431-unishift-trans-swap-out/
Just guessing, but I would think you could put any transmission back in.  The Unishift was basically just an air shifted Duplex.
I've never seen an air clutch set up on a B, so can't comment on that.
depends on which Monoshift and duplex you have??? if you are takin a 67 series out and putting one in youll be fine with mounts. same with a 72 series. I think the floor was cut for a monoshift same as a duplex with the tear drop hole. if you install the triplex there is a lot more work.
