Being you have a ASET AC 380/410 HP, you already have the same turbo as the  460P engines.   If you have a good local Mack dealer that does HP conversions , all you need is the 460 injectors and the factory 460P download. But , if your 380/410 is running correctly you should have 1660 FT LBS of torque and around 23-31 psi of boost pressure under a hard pull.  The 460p has the same 1660 torque but  483 HP and around 33 or more PSI of boost.
https://www.bigmacktrucks.com/topic/55613-more-ponies/#findComment-415793
