Sorry only have examples of a gray engine doing this how ever  if this is the first run RE check the valve set Bud to loose of a set on one exhaust will cause this on a gray engine this is a sign of lifter failure on a gray engine !
Check that  all the valve yokes are in place yada yada GET IT CHECKED!  Mp engines have been known to drop a piece out of the valve face as well !
Edited by fjh
