Hello folks:
I have a 99 CL713 with the E7460. About 6 months ago, we had to replace the exhaust manifold gaskets on it. The studs for cylinder #6 did not come out easy. Now, we are starting to notice oil coming out from around that bottom stud that holds the manifold against cylinder #6 and you can smell hot oil when it is running. Is this because we messed things up when removing/replacing that stud? or is it just a coincidence and there is something else going on with the cylinder head/valves? Does anyone know what the best way to approach the repair would be? Is this a common problem?  Thanks,
                                             -Zach
https://www.bigmacktrucks.com/topic/56179-oil-leaking-from-exhaust-manifold-cl713/
