4 hours ago, JoeH said:
What does pln stand for?
P= pump
L= line
N=nozzle
used to represent all the pre (to mid year) 1998 that had a jerk pump fuel system. E-tech was legally a PLN, but not a Jerk system and so no one ever referred to it as PLN.
Edited by Mack Technician
https://www.bigmacktrucks.com/topic/56445-pln-injectors/#findComment-419343
4 hours ago, Mack Technician said:
P= pump
L= line
N=nozzle
So what is a Jerk system? Is the endt676 a PLN system then?
Is PLN basically to differentiate between a common rail system and a traditional fuel injection system?
Edited by JoeH
https://www.bigmacktrucks.com/topic/56445-pln-injectors/#findComment-419358
Yes. Early mechanical fuel injection systems using an inline type pump were called "Jerk" systems. They were also referred to as "plunger pumps". Rotary pumps such as a "Roosa-Master" were called that, rotary.
Common Rail, and HEUI injection is not a PLN system at all. Detroit Diesel used mechanical unit injectors for years to inject the high pressure diesel fuel.
I've never seen the designation PLN used in the past in practice, but have seen it in training manuals.
  • Thanks 1
https://www.bigmacktrucks.com/topic/56445-pln-injectors/#findComment-419361
