3 hours ago, Hobert62 said:
There’s still quite a few running around in my area of central Pa.
see several down here too
49 minutes ago, Brocky said:
I never knew Ford made a narrow cab steel hauler.. Must have a roof top escape hatch with the crane unit behind the cab???
if you look closely you can see the "short door" on the driver side that opens above the fender platform.
the door ends at the lower hinge.
Edited by tjc transport
Whoever parallel parked that steel hauler is a top-notch driver!
 A rooftop hatch is used when the cargo is higher than the bottom of the door.
I would guess the cab was narrowed by a coachbuilder, a company that would do it to any make of truck that was supplied to them.
