I've got a home made one our spare parts endt676 is sitting in. It's got legs bolted to the flywheel housing and I forget what up front. I think that engine has threaded bosses on the side/front of the engine, because we had the timing cover off it a year ago to steal the camshaft.  Legs are welded to C channel bases that are web section up so our forklift can come in and grab it from the side.
https://www.bigmacktrucks.com/topic/56454-engine-stand/#findComment-419373
20 hours ago, Hobert62 said:
The one I remember looked just like a hand powered pump pallet jack. I think it was grey in color and had a cat on it i think. I don’t have a forklift but I do have several jacks I can use to make one.   I want it to be semi portable
Make one on wheels. My book says an e7 weighs about 2300-2500 depending on dry or wet. So 4 600# casters should hold it nicely.
https://www.bigmacktrucks.com/topic/56454-engine-stand/#findComment-419445
  • 3 weeks later...
31 minutes ago, JoeH said:
Not real savvy on IDing motors, but I'm guessing Cummins?
Yes.  8.3l 505 cubic inch.  6ct.     Basically a big brother to what’s in the dodge pickups.   As I type this I think I’m in your back yard.  I’m switching trailers at the Lowes in Havertown.
https://www.bigmacktrucks.com/topic/56454-engine-stand/#findComment-420897
You can get about 375hp out of those reliably but don't push more than that; in fact I'd limit to 350. Had several on generator sets and they can snap a crank with a hard load impressed upon them. It's a more robust design through the main saddles than the 5.9ltr, (360ci) engine and does fine when treated respectfully.
https://www.bigmacktrucks.com/topic/56454-engine-stand/#findComment-420914
Havertown is 20 or so miles from me, not quite my back yard but if you're from out of state then yes, you were certainly out my way!
https://www.bigmacktrucks.com/topic/56454-engine-stand/#findComment-420974
