I’d check on what components I need for the south side of the firewall. Kit may not include 2 pos switch, relays(qty 2/hi-lo), 10 amp fuse for hole 22(if you don’t already have one there for neutral switch). I’d also get a jake adjuster feeler fork. The housing won’t be painted so I’d grab a can of Mack Gray(assuming Volvo hasn’t discontinued it). Check the supplied valve cover ribbons to make sure they gave you 4 (not 2) and if they are bonded (updated) and not open ended(string cut). Replace with updated bonded ribbon if not.
Edited by Mack Technician
M
