Question
Replacing oil in Timken 5800 rear end.  Around 7 qts. through breather got me to the 1" fill plug on the forward housing, passenger side.  This level is no where near the axle centerline, and I'm concerned about getting oil up and out to the hubs during operation.
Is it standard to also fill the hubs from the outside before setting the outer bearing?
https://www.bigmacktrucks.com/topic/56766-a20-rear-end-fluid/
9 answers to this question
  • 0
What truck is this rear in?  And are you sure it doesn't have the Rockwell Timkin Posi Lube grease fittings for the axle bearings.
https://www.bigmacktrucks.com/topic/56766-a20-rear-end-fluid/#findComment-420809
  • 0
Have not found a reasonably located plug.  One is well below the axle centerline on passenger side, which took 7qts.  The next is on top of pinion bearing housing (near U joint flange) which would fill well above axle centerline.
ID tag states Timken Detroit Axle Co, and only gives fluid spec, not capacity.  I am not against just using grease, but there are proper opening to allow center section to overflow into tubes and then into hubs, but it would take a lot of fluid.  Each tube itself could hold 2qts. Sorry about photos, you can thank Steve Jobs for his upside down photo algorithms.
Edited by Nor'Easter
https://www.bigmacktrucks.com/topic/56766-a20-rear-end-fluid/#findComment-420946
  • 0
15 to 16 pints plus and additional 1.5 if axles were pulled and re installed. Same rear as LN8000, and big GMs in the 70's/ 80's
https://www.bigmacktrucks.com/topic/56766-a20-rear-end-fluid/#findComment-421140
  • 0
It doesn't need to be filled to the axle center line, just barely above the bottom of the axle tubes so oil will flow to the wheel bearings. Also, as the ring gear spins it should swirl the oil outwards, helping to circulate the oil to the wheel bearings. As you make turns and go over uneven terrain oil should flow back and forth from the wheel bearings.
https://www.bigmacktrucks.com/topic/56766-a20-rear-end-fluid/#findComment-421491
Answer this question...
