  • 0
Day time light module location Mack 2016 gu713
3 answers to this question
  • 0
The early MP equipped conventional truck had a right and left low beam relay. They later did away with them . They are located in the fuse panel by the clutch pedal. They are locate on the bottom far right. They are the small relays one above another. Position R11 and R12 on the fuse panel. There was a recall on the fuse panel for possible water damage
Answer this question...
