Hello all.   I had a 1952 mack lt show truck roll in the shop the other day and am looking for parts and advice. The customer has what I assume to be an original style clutch in the truck<see attached pics>.  The clutch grabs within 1/4 " off of the floor and chatters when it is fully depressed. I'm told there is an update kit for the clutch and flywheel to eliminate the deep dish flywheel and old style clutch and am curious if anyone has done this and could suggest a parts supplier.  Also the truck needs motor mounts along with some other minor things (input and output shaft seals, steering gear etc)  any help or info is greatly appreciated thank you!
https://www.bigmacktrucks.com/topic/56840-1952-lt-show-truck-questions/
Call Watts Truck Center. Info is at the top of this page.
