  • 3 weeks later...
What year is your CH613? I have a 2001 that the dash goes crazy and beeps with the seatbelt indicator coming on. I think there is a technical service bulletin (SB-732-005) about rerouting the grounding wire to fix this issue. If that doesnt work try unplugging the connector and clean it our with electrical contact cleaner on both the connector and the gauge cluster. Just google the service bulletin number and it should come up.
Edited by ivanuke
https://www.bigmacktrucks.com/topic/56879-ch613-dash-plug/#findComment-422669
Did you fix yours without replacing the dash cluster?
https://www.bigmacktrucks.com/topic/56879-ch613-dash-plug/#findComment-423102
