Hello, Ive contacted my local mack dealer (Vanguard) and they were not very helpful in determining the correct item to purchase to obtain an electrical schematic for my truck. I also contacted mack directly with no response. Hopefully someone here can chime in.
I purchased this from the mack eMedia center
8-217-2007
Electrical System Troubleshooting, GU, CHU, CXU, Pinnacle Chassis Wiring Diagrams
Is the CHU the same as my 2001 CH613? I'm trying to look at the reverse switch wiring from the transmission to the dash as  I am no longer able to hear my rear siren and rear back up lights dont come on and having many connectors unplugged that I need to check continuity for.
Thank you.
https://www.bigmacktrucks.com/topic/57069-correct-wiring-diagram-for-2001-ch613/
8-217-2007
Thank you.
This is the diagram for your truck reverse circuit. Go to Fuse (FU42) 42 in the right upper corner and follow flow.
Reverse Circuit.pdf
Edited by Mack Technician
Thank you for the schematic. Where could I obtain the full diagram?
Go to your dealership at 8PM with a flat of white printer paper. Ask the night foreman/service writer to print off the wiring diagrams or allow you access to print them off. If your a customer they should oblige. If they do it, come back with a large flat of bakery. Tips and food make you an “A list” customer. Night shifters at a dealership are the most under appreciated creatures on earth.
lol Thanks for the advice. Much appreciated!
  • Thanks 1
I see your 2001 schematics for sale on Mack E-Media for $54. Oddly, they are $22 for a 2000. Must be because of chassis mating. They group CL with CH on pre-2001 then the conversion occurs and chassis-groups CH with CX in 2001. 01’ is a 6 pc set.
I see that as well now. I'll place an order for that. I also have a 2005 CHN613 but do not see an option to select CHN, only CHU. Hopefully the schematic I purchased originally is the right schematic for my other truck. Thanks again for the help.
