That's a lot of weight perched behind the cab on the mixer truck. And it looks like it's got 22.5 tires. Doesn't look like it can hold more than 6 yards. Great looking trucks though, owner takes pride in his business. Out my way I only ever see front discharge mixers. Only a couple rear discharges in the area that I know of, and they're only used because they're equipped with a conveyor.
https://www.bigmacktrucks.com/topic/57141-patriotic-pair/#findComment-422421
LOTS of rear discharge units here. Only one company with front end units
most jobs are boom truck applied...sometimes two pads next to each other..no need to move
https://www.bigmacktrucks.com/topic/57141-patriotic-pair/#findComment-422428
That truck operates in far western parts of St. Louis county and is good for 66,000 lbs. In the city with that same setup you can gross 72,000 lbs.
Edited by autocardc
https://www.bigmacktrucks.com/topic/57141-patriotic-pair/#findComment-422431
Wow. I'd be worried about stopping power! Roads must be pretty flat out your way. Here in Pennsylvania we have up hills, down hills, sideways hills...
What axle ratings do triaxle have that they can hit 120k? Even with a 58k Camelback you'd have to have a 32k lift (pusher) and a 30k steer...
https://www.bigmacktrucks.com/topic/57141-patriotic-pair/#findComment-422490
