Hello fellas.i have changed belts twice today on the truck.they keep popping off.seems to me like the thin belt is the one with the issue but once it goes it takes The other one with it.everything seems to be aligned as far as pulleys goes except for the tensioner that is bit off center.could this cause it to pop off? bearing on all pulleys seem to be in good shape.please advice .
Thanks
RED
https://www.bigmacktrucks.com/topic/57331-mack-cv-serpentine-belt/
13 minutes ago, R.E.D said:
Replaced both tensioners and belts .drove truck 10 miles and the thin belt is already starting to shred.nothin seems to be rubbing
Is any ancillary drive, (a/c compressor, alternator) etc. running smooth or vibrating during operation? Make certain the clutch is locked in and turning the a/c compressor when the system is running. When the belts are off are the sheaves, (pulleys) rotating smooth and easily by finger pressure?
If everything is in alignment I would suspect the front bearing in the a/c compressor clutch first unless certain the compressor is running constant.
To clarify, as I'm not real familiar with CV's, the thin belt is to the air conditioner from the fan? Separate from the serpentine belt?
Take the  belt off the AC for a day (driver will hate me) and see if the serpentine belt holds up. AC is a creature comforts, not mandatory. Engine water pump and fan spinning are mandatory.
The cv uses two belts.wide belt only goes from crankshaft to fan pulley and is has it's own tensioner.the thin belt runs the water pump , alternator , ac compressor and it goes thru an idler pulley and it's driven by the fan pulley .so just undoing the ac would render the belt two long
Understood. That's a weird serpentine setup, I would have expected crank, water pump, alternator and tensioner to be together and the AC to be on it's own, driven by the fan/water pump. Are you buying belts from the dealer or cheap Napa belts? Napa is fine for cars etc but they're sh*t for trucks IMHO.
5 hours ago, steeler said:
Maybe a stupid question, but is your plastic idler pulley still there? I've seen them go bad and break off the engine completely.
Yes it is .I hate to throw parts at a problem without properly diagnosing the issue but if I can't see anything rubbing against belt today , I'll be changing that plastic idler pulley in order to eliminate variables.
These used to have issues with fan hub bearings packing up on the AI engines  due to the extra heat  when the truck was first introduced! is it possible the hub bearings a toast! just throwing that out there! Also the crank  Damper is a possible as mentioned however never seen one fail out of the blue before! fan hub bearings make a whining noise when standing in front of the truck!
