1964 or newer. The 1963 and back had a more curved, or wrapping windshield in the lower corners.
  • Thanks 1
It could be titled a 1967 but most likely 1966 as the latest year for that cab design. 1967 - 1972 used the newer style cab.
  • Thanks 1
'66  4000 series, seeing the dual exhaust either the 305 V6 or the 351 V6. Got a clean potato hauler on on the farm on L.I. bout 38000 miles I'd sell
Definitely a '66, has the square 'G M C' letters in the grille.  '65 and earlier are curved.  Dual exhaust and 10 stud Budds usually indicate 6000 or 6500 series, which would have had a 401 or 478 V-6.  But, this particular truck is Canadian!  Series designation on the cowl instead of the door, no 'V-6' emblems.  It's probably an Oshawa built 960 series with a new-for-'66 366 Big Block Chevy engine.
I had a 1964 3/4 ton GMC w/305E V6 engine and it would pull just like a 350 Chevy engine in a new truck, (1976). 7.50X15 tires on three piece "widowmaker" rims. It was my first pickup truck and that thing and my Hobart engine drive welder went a lot of places together fixing bulldozers, scrapers, backhoes, truck frames, dump boxes, and just about anything else needing welded for several years. Damned thing had a "Detroit Locker" differential in the back, and springs so stiff it hardly sagged with a ton in the bed. I still have the original shifter knob as a momento too.
