36 minutes ago, JoeH said:
Just check every fuse and replace any that are blown.
with a test light.  :)   key on
Edited by 41chevy
https://www.bigmacktrucks.com/topic/57611-fuses/#findComment-424928
8 minutes ago, JoeH said:
What'd shock me is if it had fusible links. Ran into those on a junker PoS 89 f250 gasser I bought, never could get the truck to run right.
You still see those on critical circuits in automobiles. Only places that are high current loads such as lighting or HVAC runs within engine compartments as example.
https://www.bigmacktrucks.com/topic/57611-fuses/#findComment-424962
