I looking for help to fix my 1995 CL700.  It has an E -7 454 engine. My engine has erratic RPMs.  Even if the truck is just idling it will rev up very high by its self.  I have change the throttle pedal with no effect.  The truck will even rev-up in any gear or at any driving speed.  Not sure what I can check next.
Any help would be greatly appreciated.  ???????
https://www.bigmacktrucks.com/topic/57899-1995-mack-cl700/
It may sound out of kilter but change the air filter element(s), and tighten all the clamps on the induction system replacing any compromised or worn rubber parts; especially the ones leading to the turbocharger inlet. Also need to pressure check the charge air cooler and have it cleaned if dirty internally.
Some may ask why to these suggestions but there is a method to the madness and I like the bases covered.
https://www.bigmacktrucks.com/topic/57899-1995-mack-cl700/#findComment-426440
