Attempting to identify a couple main/aux transmission setups. The ID tags are as follows: Main - Fuller 5H74T,  Aux - 8031e....I'm guessing that the main is simply a 5 speed direct in 5th (looks like single countershaft), but is the 8031e an old spicer 3 speed aux transmission?
https://www.bigmacktrucks.com/topic/58046-mainaux-transmission/
6 hours ago, tl1975 said:
It's been a while since I've been exposed to anything with 2 sticks, but I believe you're correct about the auxiliary transmission being a 3 speed. But look closer at the tag, because it may say 8031C instead of E.
Will do thanks!
https://www.bigmacktrucks.com/topic/58046-mainaux-transmission/#findComment-427416
Typically the first two digits are the torque rating(80= 800 ft/lbs).  The 3 is three speeds.  Not sure what the "1" denotes.  The letter is typically the gear ratio.
I used to have a Spicer sheet saved that listed everything.
Found this:
AUXILIARY TRANSMISSION: Spicer 8031G, 8035G; reductions: 1.29, 1.00, .84.
8031C, 2.59, 1.00, .75.
8341A, 2.40, 1.29, 1.00, .84
Edited by Freightrain
https://www.bigmacktrucks.com/topic/58046-mainaux-transmission/#findComment-427436
That Fuller 5H74T you mention, it's an ancient 5 speed transmission, I think it pre-dates the T905 series. It's very small (if I'm remembering correctly), and I don't even think you can get internal parts for those anymore.
https://www.bigmacktrucks.com/topic/58046-mainaux-transmission/#findComment-427715
