I have said all of my working days that a trans will not vibrate unless output shaft was bent or off center some way.I have a CH I have been driving that last DEC started to vibrate in the drive line.I have had drive line balanced and messed with the ride height and u/joint angles plus replace front rear end power divider inter and out cam with new imput shaft with no improvement and had started to get worse.Thrusday the trans which is a 9 speed mack started to slip and not make range shift right a so I pulled it and change to a 18 speed mack.I drove it today and its as smooth as a new car.I guess I never get too old to learn something new.
https://www.bigmacktrucks.com/topic/58370-vibration/
