I have a 01 E-tech that started oiling the right side of the chassis and block with the tell-tale draft tube slobber.  Pulled the insert out of the pot on the front right corner of the engine and cleaned it out in solvent and reinstalled it - didn't seem like anything unusual (as far as crud level)  but also  didn't help the problem.  In the last 13K miles it went through 2 gallons of oil.  As far as performance it runs great, no power loss, no abnormal smoke, no cylinder miss - even when cold.  I've been sampling the oil for the last 3 oil changes (20K interval) and nothing comes back on the samples that even comes close to suggesting it has anything going on - no excessive wear metals, no high viscosity or oxidized oil - (all come back #1 on Horizon Labs report - 1 being best - 4 being worst).  Today I pressure tested the turbo thinking maybe it was boost pressure escaping down the drain tube causing the problem - I did have pressure escaping down the drain pipe but after the fact was advised by a local turbo shop that all turbos will leak down the drain tube when tested, I've been a mechanic for 30 + years but don't claim to be a tur bo expert so I'm not 100% sure this is true.  Last thing I did was put it back together and heat checked the exhaust manifold - all were within 15 degrees. At this point I'm at a loss as in my experience anything that is on the verge of needing an overhaul always shows high oxidation and high viscosity and usually runs poorly or misses, not this thing.  Anybody have any similar experiences with any other E-techs doing the same thing ? Sorry for the long read, just trying to put all the info in up front.  Thanks in advance
https://www.bigmacktrucks.com/topic/58483-2001-e-tech-427-excessive-blow-by/
703K unsure of the hours.  Not 100% sure it's the original engine either, one of the company's long term drivers thought there was a reman engine installed in it at some point but he wasn't positive. Agree on the compression test, that would tell the condition of the internals.  As for the oil leak, didn't want any issues with DOT - its to the point it has the front rear covered - won't rust :unsure:
  • Thanks 1
How much pressure is the turbo putting to the intake manifold?
If the DOT is that fussy that they're nitpicking s little blowby residue then wash the engine once in a while. In the 11 years I've been driving I've been pulled over twice in my dad's fleet. They're usually just checking brake adjustments and obvious things. Once they mentioned oil leaks, commenting that it'll deteriorate rubber hoses. It was more of a helpful/instructional comment than an "I'm gonna slap a big fine on you" comment.
Edited by JoeH
I agree if its bothering you  do the above how ever if its running good leave it alone!  I seen these with a fare amount of blow by and still be reliable as hell!! Oil is cheap! As a side note pay attention to the situation in your mirrors or have someone follow you   if you have any longer grades in your area with the engine brake on or pulling see if you notice the blow by increase  there is a vague possibility that the turbo may be causing this issue  Seen this happen several times ! just something to look for!
Edited by fjh
Yeah it’s one of those deals where you could spend $ on a turbo and not repair it or maybe it would. Talked to a guy who had in framed quite a few E-techs, he said he has seen a few run with no performance issues while having excess blow by, with all piston rings broke except the top ring which caused it to burn oil but maintain enough compression to maintain decent performance.  This thing is really blowing oil out, to the point on a 150 mile trip it’s dripping off the front rear.
I say test, verify blow-by and do an in-frame as necessary. Check for critical stuff that will ruin you again, like air intake leaks from filter housing to turbo causing dusting of sleeves.
IMO....
A little hot leakage oil will eat a bite of whatever rubber it lands on then hangout and turn to black dust cake and protect surrounding metal from road salt for the next year.....
A constant stream of hot leakage oil will turn your truck into a rubber buffet line, destroy harness wires, Make trans mount rubbers into gummy penguins, turn brake hoses to black licorice and when you rake your finger nails across your rear air bags you'll be leaving grooves.
Edited by Mack Technician
That sounds like it's time for rings.  My trucks sit on people's driveways a lot, I can't be leaking that kind of oil.
