Hi guys. As its impossible to find any information on the Australian built EA470 macks can someone please tell me if there is any difference in the bottom ends with the standard E-tech and the CCRS?
Rebuilding the bottom end and can get a kit cheap for a standard E-tech but mine's a CCRS model.
Are there any differences with the bottom end?
Thanks.
Tom
17 minutes ago, 880joe said:
Bottom end should be the same I believe the only difference in the two are in the fuel system
Would the pistons possibly be a different depth or something?
Might just take the drive with a rod and piston and compare but would like to definitely know if its possible.
  • 1 month later...
On 10/6/2019 at 1:21 AM, PUP said:
Hey Tommy,
How'd you go with the bottom end? I have the same engine and like yourself experiencing the difficulties researching any info.
Would you know where to acquire a workshop manual?
Cheers Dan
Hi mate, I downloaded a workshop manual from online. Can't remember the site but can find out if you still need.
As for the kit I just went with a ccrs 1 to be safe.
Went with a PAI Industries kit. If you're from Australia that was the cheapest and I got it from Gleemans truck parts.
