Have two here but I am not 100% sure if they are OEM.
One is out of Cummins truck (B73) with a core thickness of 2.75", 4 rows of 1/2" tubes in a staggered pattern with 10 fins per inch.
The one out of the B75 is 2.375" thick with the remaining specs same as above.
https://www.bigmacktrucks.com/topic/58607-b73-or-75-radiator/#findComment-430060
                             Thanks for the reply, the one that was in it was 3/4 tube 4 row 3.00 thick. But in talking to the builder in B.C. those 3/4 tube radiators flowed to fast. and the coolant would not cool down enough exiting the bottom tank.
                             Years ago they built 1/2" tube five row for Cummins powered loggers. Thanks again.
One ping only
https://www.bigmacktrucks.com/topic/58607-b73-or-75-radiator/#findComment-430096
