2000 460  It was rebuilt a year ago. Since the overhaul I been making oil. In 10,000 miles its up 3/8" above the mark. Before the overhaul it was fine ,I used to add between changes.  This has to be from the EUP o rings.?  correct.?  Is there any other place you can think of for fuel to get in the oil.?  I was thinking the plunger in the EUP pump but it didnt do it before. Just since the EUPs were out and put back in.  Here is the latest oil sample report, not good.  Thanks for your help.  Where should I start.
80-190803 (2).pdf
https://www.bigmacktrucks.com/topic/58719-making-oil/
I changed the fuel transfer pump no difference.  Whatever it is its getting worse. Last October the oil sample was 1% now almost a year later its 2.5% and the truck doesnt work from Jan til March. I run to a local asphalt plant. So basically 9 months it went from 1% to 2.5%.  I plan on changing the o rings on the EUP pumps this weekend. After that I have no clue..  Need help. Thanks
https://www.bigmacktrucks.com/topic/58719-making-oil/#findComment-430576
In them 9 months I only put 40,000 miles on.
https://www.bigmacktrucks.com/topic/58719-making-oil/#findComment-430577
Mack EUPs occasionally go chronic and leak no matter how You dress and install them(with standard o-rings). Mack made a special production of seals called the “Delta seal” kit. The lower ring is made of three individual parts that lay at complimentary angles. Get a 6 set and install them. I don’t believe Mack made the delta set a standard factory production install, but saw random cases where EUPs leaked and standard soft kits didn’t resolve the issue. Suspect maybe R&R of unit pumps eventually create little vertical scars on the wall of bores?
Edited by Mack Technician
https://www.bigmacktrucks.com/topic/58719-making-oil/#findComment-430585
https://www.bigmacktrucks.com/topic/58719-making-oil/#findComment-430645
They were only taken out and put back in one time. They are original 700,000 miles. I figured I would change them and get rid of the stumble at the same time. Them delta kits are pretty pricey at 100 bucks each.  I cant see an o ring getting worse that s what led me to believe the plunger seal. Im also thinking a cracked head where the fuel return flows through. They are reman heads , not original. Already had trouble with one 3 days after the rebuild.
https://www.bigmacktrucks.com/topic/58719-making-oil/#findComment-430692
You can be right. This came from the mechanic through the parts guy, but it could be for 6.  I do know the regular o rings 2 for each pump is 180 bucks for the set ,12 o rings. That sounds really high for 12 o rings. 15 bucks each, They might be Viton but dont know
https://www.bigmacktrucks.com/topic/58719-making-oil/#findComment-430759
