The engine swap "should" be relatively easy.  Hard to tell without seeing what it is. Don't think much else would be of value to you.
If the army truck is complete and functioning, I would leave it complete and source a replacement engine for your B-61 from something else.
  • 3 weeks later...
  • 3 months later...
The mil-spec ENDT-673 was a one-off for the project, fielded from '66-'68 before being replaced with a Hercules Multifuel.
Very few 'normal' Mack parts will fit that engine, especially around the bell and water pump/oil cooler/thermostat.  It has a two-sump oil pan with special pumps, too.
It was known for good mileage, low maintainence, and good longevity.  Just expensive.
dg
dg
Yup. I have one on a stand in the shop that is complete. Pulled from a 68 M54A1 several years ago.
Edited by Rob
