Working on a 94 CL714 originally equipped with an electronic engine, engine was swapped by the previous owner to a 90 model E7-460 (with poor work quality) having some issues with the dynatards and  have narrowed it down to the wiring that passes from outside the cylinder head through the side and into the solenoids. Original wiring appears to have some sort of cotton insulation and is broken internally (continuity test shows open when manipulating the wiring by hand). The wiring is molded into what looks like a pipe fitting in the side of the head. Does anyone have a part number for the wiring harness or some kind of sealed bulkhead connector that threads into these cylinder heads? Thanks in advance, Any help is appreciated.
https://www.bigmacktrucks.com/topic/58865-dynatard-pass-thru-wiring/
