- 0
3/8 coolant hose leaking
Question
Mackcxn613
I had a bad coolant leak with upper radiator hose that connects to the top of the motor, I replaced the hose I believe it was 6”. Put it back together it’s still leaking, later discovered there was a hole in the metal pipe that connects to the hose I welded the hole gridded the weld down the put jb weld over my weld for some extra security. Put it back together no leaks 🎊🎊🥳. Then later discovered another hose leaking the gies from the radiator to coolant tank! Its a 3/8 hose 200-300 psi hose. My question is can i just replace the hose and use clamps instead these quick connects ends on the hose?
DFEF12E8-7D5A-4819-BBA3-91DE91417AFB.MOVLink to comment
https://www.bigmacktrucks.com/topic/58924-38-coolant-hose-leaking/Share on other sites
1 answer to this question
