I started using black beauty it cuts rust and paint and last pretty good in my blast cabinet. you use glass bead if your doing pistons or some other parts that the surface is critical. For my pressure pot outside I always use the black beauty.I found the ground glass is good but after a time it really gets dusty.
  • Thanks 1
https://www.bigmacktrucks.com/topic/58948-glass-bead-cabinet/#findComment-431834
I have used aluminum oxide and it last quite awhile.  So does steel shot.  Garnet in my pressure pot can be recycled a few times.  Glass beads are good for fine work like mentioned above, but I think it breaks down quickly compared to aluminum oxide , garnet or steel shot.
  • Thanks 1
https://www.bigmacktrucks.com/topic/58948-glass-bead-cabinet/#findComment-431851
You can’t beat the finished product all well worth it but thinking of building one myself out of an old drum But as little as I use them I’ll probably just pay somebody will be using it soon for hubs and rims
Sent from my iPhone using Tapatalk
https://www.bigmacktrucks.com/topic/58948-glass-bead-cabinet/#findComment-432070
