I have a bunch of parts that were removed from a 1997 e7 350 running engine. Block was used for a boat engine rebuild and the rest of the parts from the marine engine were used so these are left over
Parts include: Oil pan, Heads, jakes,Valve covers, injector pump, Cam, Crank, Injectors, turbo, manifolds, Many more - let me know what you need. Very reasonable prices!
https://www.bigmacktrucks.com/topic/59213-mack-e7-mechanical-injection-parts/
Some parts claimed - heads, jakes, valve cover, flywheel and bell housing no longer available.
Still available are: Crank, cam, rods, injector pump, oil pan, injectors, turbo - more, ask as needed.
Thanks
Photos of the injector pump, crank, and cam attached.
  • 5 months later...
