Can't help as there are 4 pieces to the dashboard or do you need them all?
The R, DM, use the same dash with little modifications if any. If the RW dash is not available it maybe for these other model Macks. The RW dash was available about a year ago when I purchased the 2 main pieces and was going to make the other 2 to mount the gages and switches. The old original dash was metal and naugahyde covered the new one is plastic and textured. There are probably superseded part numbers that the parts guy did not look up for the parts you need.
