I'm still on the hunt for a rear rear differential in 3.65 ratio. It must be an iron differential carrier as it's for an air ride setup.
Once a rear rear is located I'll have a front rear to sale, or trade.
https://www.bigmacktrucks.com/topic/60077-365-ratio-crd-93a/
I did last year with nothing available. VanderHaags had a used one they were going to look into and were supposed to call back but I never heard anything so figured it wasn't any good.
I should probably try them again.
Thanks,
I see this on their website but I think, (not sure) I have the different torque rod attachment:
https://mandersdiesel.com/mack-crd-93-3-65.html
Edited by Rob
https://www.bigmacktrucks.com/topic/60077-365-ratio-crd-93a/#findComment-437452
Believe I have located one of these but it needs pulled to ensure it is good. I will have to drill and tap the case for studs but I have that capacity. No core as it's used but private party from a retired and parted truck when the engine went bad.
https://www.bigmacktrucks.com/topic/60077-365-ratio-crd-93a/#findComment-437804
  • 1 month later...
Forgot to update this posting but I did find one but haven't got it home yet. Actually he needed a front rear for a truck, and had an extra rear rear so a trade deal but I'll need to drill and stud the casting as it's from Camelback suspension.
https://www.bigmacktrucks.com/topic/60077-365-ratio-crd-93a/#findComment-440696
53 minutes ago, Dirtymilkman said:
A whole cutoff sounds a lot easier.
Making two single axle drives from a former tandem.
https://www.bigmacktrucks.com/topic/60077-365-ratio-crd-93a/#findComment-440840
