I have recently purchased a 89 Mack super liner with a e6 350 and Mack 9 speed, I use the truck to move equipment from job to job dozers excavators etc... truck really lacks power my old r with 300 and a 5 speed with pull about as much, suggestions on power increase?? I have also thought of an v8 Mack swap how hard would this be?
https://www.bigmacktrucks.com/topic/60255-mack-superliner/
If you are working in the lower end of the range as it sounds like you are moving equipment short distance as in jobsite to jobsite, a 300 "Maxidyne" will easily outperform an "Econodyne" 350, (IMO) if both are in good tune. The "Maxidyne" settings are more optimized for that where the "Econodyne" is more of a road use setup.
Lot's of room to work with that 350 however, till you get to the point where it will destroy itself by physical limitations.
https://www.bigmacktrucks.com/topic/60255-mack-superliner/#findComment-438495
