  • 1 year later...
Hey! I have for you some factors to consider when purchasing a used Mack truck
A new Mack truck could be way outside what you'd consider a reasonable capital expenditure, but this doesn’t mean you can’t find a good value in a used truck. You just have to be careful about your purchase. Here’s what you need to think about while searching for your used truck.
Price
Price is one of the most important factors. First, you need to determine what your budget is for the purchase. Be realistic about pricing, especially if you have a lot of requirements, which could add more zeroes to the price tag. A used Mack truck can be a very cost-effective solution to meet your needs. You’ll often find the best quality and prices at a Mack dealer.
Little Difference Between Brand New and Lightly-Used Commercial Trucks
A used commercial truck purchase lowers your financial obligation. If the truck doesn’t work out for your needs, it'll be much easier to make most of your investment back when you resell the truck versus if you purchased new. There is very little difference in quality as well. If a used Mack truck has only been lightly used, it should show little wear and may even appear to be brand new. Be sure to inspect every part of the truck to ensure that it’s in good shape.
Less Risk Associated with a Used Commercial Truck
There is much less risk for you when you purchase a used Mack truck. As long as the truck has only been slightly used and you have the information about its previous care, it's not likely that the truck will break down anytime soon. You can take on less of a financial risk than you would with a new truck.
Truck Service Parts & Availability
Since you are buying a used truck, you’ll want to be sure you have access to service and parts. Depending on the age of the truck, this may not be an issue. However, you should ask the dealer about their service options and if any parts are hard to find.
Edited by ramyc
https://www.bigmacktrucks.com/topic/60292-best-truks-in-2020/#findComment-467701
