5 hours ago, Quickfarms said:
Still looking for these parts
I have one broken on my 78 RL. Do you have a right one I could make a mould from? My left side is good as are my brackets.
This setup started with the 1975 year model.
https://www.bigmacktrucks.com/topic/60395-fender-extensions/#findComment-440527
Are the Hayward ones different?
The truth is I need a drivers side bracket for the 1985, it all rusted out but that's the only rust on the truck so I am wondering if it was changed at some point.
The 1975 Hayward Mack has different style ones on it that I think are ugly and need a bunch of repairs
So I was hoping to find some replacements in better condition before I spend a bunch of time fixing what I have
https://www.bigmacktrucks.com/topic/60395-fender-extensions/#findComment-440595
Get me some good detailed photos of what you have. My truck is also Hayward built and 1978. I can compare your's to mine and quite possibly make you a set or dimensioned drawings to fabricate them yourself if the same as mine.  I have a broken plastic on on the right side; left is fine.
https://www.bigmacktrucks.com/topic/60395-fender-extensions/#findComment-440610
The white truck is a 1985 and I like that style better but the drivers side bracket is rusted out, and it's the only rust I have found on the truck. The truck started its life with Texaco and i found it in California. At some point in its life the frame rails were replaced
My 1975 has a different style on it and they need some serious repairs
https://www.bigmacktrucks.com/topic/60395-fender-extensions/#findComment-440873
I really don't have a good photo of mine but the mounts are a series of flat strap and square tubing welded together in a framework. This is the only photo I can find for now. I'll be out to the shop tomorrow and can grab more:
https://www.bigmacktrucks.com/topic/60395-fender-extensions/#findComment-440874
  • 1 month later...
Hi there. I appreciate your inquiry and it could be done, but such a small quantity wouldn't be cost effective I'm afraid. I don't have current stock of materials and to garner favorable pricing, a much larger order than a small run would consume would be required.
A cursory glance appears a run of four pairs, (eight parts in total) would consume a very minimum order, but pricing would still be close to $225.00 per side in black, or white gelcoat. A bit much for a hobby expense other than a discerning restoration. What I build however will not be subject to breakage like the originals.
Thanks,
https://www.bigmacktrucks.com/topic/60395-fender-extensions/#findComment-444662
  • 1 month later...
