Hey guys just wondering if the newer mack mru 2015+ with t310 and t318 transmissions, if the clutch still gets adjusted the same way as the older mr688s models?
By old way i mean put a wrench on clutch adjusting bolt with prybar have someone step on clutch and push in spring to turn the bolt
Thanks
https://www.bigmacktrucks.com/topic/60460-clutch-adjustment-mru/
The
22 hours ago, mcratchet1 said:
is there a proper technique for setting the clutch brake
The  technique is simple enough .you want the clutch brake to engage right before the pedal hits the stop in the cab aprox 1/2 inch off the floor  this can be adjusted via the clevises at either end of the cable or by the sloted clutch arm on the side of the trans! once adjusted then proceed to the inside adjustment!
