A member of my family just purchased a 1978 rd600. He was told it had a 237 engine ,5+2 trans, and 58 rearends. this truck has tip turbine aftercooler and I thought only the maxidyne 300 series had tip turbines. I asked if it was a 675 or 676 and he didn't know. So if any one knows if a 237 came with atip turbine I'd really like to know?
https://www.bigmacktrucks.com/topic/605-mack-237-engine/
I have a 1978 285 HP tip turbine. with a 2 stick 6 speed.
engine code
ETAY676 Maxidyne
283HP@2100RPM
1080 ftlb @1020RPM
the ETAY673 and ETAZ673 I belive were econodynes and rated to 315HP 1080ftlbs. They were recomended to use with gearboxes with 9 + speeds
I think the 237 was a ENDT675 with 900 ftlbs.
look on the pass side of the engine for a tag with engine code info
https://www.bigmacktrucks.com/topic/605-mack-237-engine/#findComment-2802
I purchased a wrecked '78 RD model for the engine to install in my '64 B61 that had a bad engine. It sounds like I have the same engine you are talking about. It has the tip turbine fan with side mount aftercooler. Here are the numbers off the front cover of my motor: ETAZ673A. I am in the process of installing it in my B model right now....
https://www.bigmacktrucks.com/topic/605-mack-237-engine/#findComment-2834
The 237 motor does not have a tip fan. Also the pump should be different. the difference in the pumps are easy to tell, the 237 pump has a sloped top on the govoner(where the 6 bolts hold the cap on to keep people out of the fuel adjustment). the 300 motors have a flat top on the govoner. thats how u tell whether its a 237 or a 300.
joe
https://www.bigmacktrucks.com/topic/605-mack-237-engine/#findComment-2854
