  • 0
1996 E7 350 overflow valve? P7100 pump
Question
Whats up y'all. Any ideas would be much appreciated.  1996 all mech 350hp Bosch P7100 pump. Rough idle when cold gets better on warmer days. #1 and#2 cylinder seem to be missing. When i crack fuel lines on these cylinders very little change in running. Seems like low fuel pressure. Did filter change ran fuel cleaner didn't help.  Low on power and low egts (loaded maybe 700). Have cummins 8.3 with P7100 pump as well and has overflow valve on pump return line. These valves go bad on p pumps and sometimes cause this problem, but this truck doesn't seem to have one. Do these pumps on macks have them? Thanks in advance for any thoughts.
https://www.bigmacktrucks.com/topic/60721-1996-e7-350-overflow-valve-p7100-pump/
3 answers to this question
  • 0
If it has a miss on thous cylinders you may have an issue with delivery valve washers! on certain models of the pump there are copper washers below the delivery valve nut that can crack and leak by! I would take it to a fuel shop if you have one near by and have it checked It can be done on the truck but you have to have the proper socket to remove the delivery valve nut!
just my opinion!
  • 0
Thanks. Ordered socket today. Called local diesel shop and asked if they have these washers, they said yup, they good bad a lot, said could be cooper or steel have to remove first. Will see what happens. thanks for help.
Answer this question...
