does anyone know a source for the old 700x24 tires, or also called 6x36. Other than Coker tire who wants around $700 each. I was told that there was some farm equipment tires in this size. Cannot find anything. These are for a early AC Mack turck.
Thanks Don
https://www.bigmacktrucks.com/topic/60775-ac-mack-truck/
Universal vintage tire, but they are around the same price. I believe Coker owns the molds and produces the tires. The reality is that tires are expensive and producing them in small batches to meet a low demand is costly. The problem with trying to find used ones is that they will most likely be dry rotted junk due to the fact they are so outdated. I have bought several sets from Coker and I am storing them in a cold dark place for when Coker deems them no longer feasible to produce
https://www.bigmacktrucks.com/topic/60775-ac-mack-truck/#findComment-441654
ekennedy21 is correct.  But there are some new 4 ply tractor tires and turf tires in 24" rim size that will work for knocking around.  Miller tire in Wauseu (sp), Ohio has a catalog with these in them.  They are only 4 ply with about a 2500 pound capacity, but we are talking parades, etc, not running a load.  Might work for what you want to do.
https://www.bigmacktrucks.com/topic/60775-ac-mack-truck/#findComment-441713
