2001 mack rd drove truck and parked it next day it would not crank the vecu computer is not getting any power the vecu is good put it in another truck the main computer is good also tested it with another truck changed ignition and starter relay do not know what else to do can anyone give me any advice  thanks   JR
https://www.bigmacktrucks.com/topic/60779-2001-mack-rd/
Did you try jumping the solenoid? Triple check the truck is in neutral, stay clear of any spinny bits and touch hot wire to small terminal on starter solenoid. Engine should crank. Have a dead spot on the starter in my E7 and every couple months or so I gotta do this. I should probably change my starter....
Sent from my SM-G892A using Tapatalk
https://www.bigmacktrucks.com/topic/60779-2001-mack-rd/#findComment-441688
