Recently purchased a R686ST that has a Mack T2090 Mack reman transmission. On the passenger side near the bell housing it says, wet clutch only fill with automatic transmission fluid. What reservoir is it referring to? And will appreciate any tips or info on maintenance/dos and don’ts  Thanks.
https://www.bigmacktrucks.com/topic/60999-t2090-transmission/
Kevin probably knows way more about the wet clutch era than I do, but IIRC the Spicer wet clutch was offered as an option by Mack and GMC around the late 60s into the 70s and seemed to have mostly been installed in UPS tractors. By the time I became a peak season UPS feeder driver in the 90s they'd all been converted to dry clutches.
https://www.bigmacktrucks.com/topic/60999-t2090-transmission/#findComment-442774
 Terry It is not a plug, prolly where a plug was supposed to go IF it had a wet clutch lol. I wasn't sure about it which was the reason for asking, the bottom plate and grease tube threw me off, just dbl checking since its my first big truck . Thanks everyone.
https://www.bigmacktrucks.com/topic/60999-t2090-transmission/#findComment-442783
