I have a 2000 Mack Ch613 that I am replacing the engine in currently. It has a E7-460 Etech with 690B Jacobs Engine Brake and I need some information. Thanks for your help!
Injector torque?
Jake brake housing to rocker arms torque?
Jake brake lash settings?
https://www.bigmacktrucks.com/topic/62053-torque-specs-and-lash-settings/
Just A note to Tech's literature here !His last pic shows the actuator pin side view ! The little mushroom end had a  a tendency to break from time to time you should always check these when setting the valves and jakes replace the screw if broken and good luck finding the broken bits! 😒
