We overhauled an 05’ Granite this winter and turned it into and old style E7 Etech.   It’s a running mother trucker now.   No dyno, but we maxed everything we could and got a hot download for the computer.  Allegedly it should be a 460 xt.
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-451984
Somewhat doubting that the grey tri-axle is destined to be a tractor.  Wondering if the fifth wheel is intended for transporting other rigs from the factory.  Frame rails extend too far behind the tag to be a useful tractor in my opinion.
Ed Smith
1957 B85F 1242 "The General Ike"
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452176
Its actually a tri drive, no tag axle. I thouhgt it was an odd setup too. It does have the pogo stick with trailer cable and airlines. They have special clamps and mounts they use for transport. I doubt a customer would spec all that just for transport from the plant
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452186
I get it... pogo stick and associated lines throws me off a bit more than the 5th wheel which is easily removable to another unit.  Just cant imagine using it as a tractor with the frame rails that far behind the axles.  There is obviously a ton of stuff it could be used for.  Maybe going to Canada and will get a dump body and the air and power will be used for a dump trailer?
Ed Smith
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452195
They use tri-drive tractors like that in my area and west of here. They have to have the long wheelbase with our axle weight laws to get max AGVW.
I like the 6x6. Reminds me of a new age RM. Only the RM was a better truck, LOL
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452207
So your saying the 5th wheel is going to be where it’s at now? That much frame behind the last axle? Got to be a special trailer. Like to see 1.
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452213
Well I too was thinking some sort of heavy haul tractor and it was set up to pull the jeep (right term DW?) then again doesn't look heavy enough to be a heavy haul tractor.
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452230
My Guess would be: That it gets a Chassis Dock & a few other Things when the Customer Fits Fenders  chassis walkway Plate & whatever else they Want/need....
Because those that matter...
don't mind...
And those that mind....
don't matter." -
https://www.bigmacktrucks.com/topic/62662-granite-tractors/#findComment-452236
