A 5/16 fine bolt 11/2 inches long with a  thick body washer and a ladys foot pry bar will do the trick !
That said !We have had these so stuck in the bore that Had to use a porta power to remove them and the injector sleeve came with the injector hopefully your not in that predicament!
Edited by fjh
https://www.bigmacktrucks.com/topic/62689-e6-4v-injector/#findComment-452154
