Dennis Meehan (oldmacks.com) had a tilt-nose B-model on his lot a few years ago.  He said it was a factory prototype.  If I recall correctly, it was all steel, though.
Seems like it had an inter-cooled Maxi stuffed into it.  Been a while...don't remember as clearly as I used to.
Dennis was telling about all the parts you had to buy if you hit a B in the nose.  It was a butt-load of stuff.  By comparison, the same damage to an R required only a handful of part numbers to fix.  Sounded reasonable to me.
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452655
17 hours ago, Maddog13407 said:
you sure that's Australia?? looks a lot like the back lot of the test center in Allentown?? and the steering wheel is def on the left
Can only go on the information provided
A few questions that come to mind are
Why would Mack in the U.S. or Australia even muck around with this as the R model would have been well on the way by then
I agree the steering wheel looks to be on the left as I  cant see no shaft or box or linkage on the picture
The exhaust is on the right which most in Australia are on the left with a  ertical exhaust
As far as I know all the B models from new in Australia had a under slung side exiting exhaust
Even the first 5 years or so of R models were like this
I don't know either way but find it interesting  just the same, I had never heard of this before
Paul
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452778
I was told they offered a fiberglass tilt nose on the later B53’s.  I do not have literature to back this up.  I have seen several that look just like a regular B model hood without the seams.  There was a B61 near me with a fiberglass hood.  They claimed it was the first B6 built.  The serial number plate said B61T1000.  The stamp was ground off the frame.  I think there was some funny business going on there. Mike.
Edited by yarnall
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452797
Yes after thinking it over I will come to the conclusion there’s nothing wrong with it at all except for manual steering..... Kenworth cabover what is the hardest one I can ever remember couldn’t move the steering wheel  at all if the truck wasnt rolling a little bit
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452832
A one piece nose would make it impossible for me to work on my truck in the garage since the stall is only as long as the truck!!  Its a PITA as is, but at least I can work on it.
Those Clariben hoods with quad lights are not my cup of tea.  That stock looking hood is nice.
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452841
21 hours ago, Maddog13407 said:
there was never a B62T far as I know. the single axle version was a B60 and tandem was a  B62. both replaced with a B68 that covered both variables
My fat fingers typed 62 instead of 61. I corrected it above. Mike.
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452862
I took these pics at the ATHS convention at South Bend in 2011. I'm still looking for a pic of the complete truck. I'm pretty sure this was a custom built doghouse. I know Mike Harbinson, Rob and Larry were all there. Did any of you guys get info on it?
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-452872
  • 3 weeks later...
On 6/5/2020 at 3:49 PM, Vladislav said:
Blue truck is what was for sale at OldMacks.
Purple hood was offered by a company in the States. I don't recall details excepting that Paul 41Chevy posted the link.
As you can see in both cases the look was Ok.
That was the one I saw at OldMacks.  Thanks for posting that, Vlad!
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-454502
  • 1 month later...
I’m really thinking of cutting my sheet metal  and converting it into a tilt front.  Just got the engine out and once I get the new steering box squared away that will be next.
I spoke with Kevin All he is in the process of building and going to sell original looking fiberglass tilt fronts for the B.
https://www.bigmacktrucks.com/topic/62773-tilt-front-b-model/#findComment-459808
