Hi guys, i am trying to get my high beam headlights back up and running. So far i have ruled out that its the fuses.
Both High and low beams will turn on, the low beams work fine but the high beams only work when i use the flash function on the turn signal switch.
https://www.bigmacktrucks.com/topic/62933-high-beams-not-working-2000-mack-vision/
