Found out and it has to do with the year truck was made.
55QS23 Curved handle was used up to 1979
55QS29309A Straight handle was used after 1979
Makes sense that the A designation is usually a revision for Mack
Both worked with the padded interior door panels with no rubbing. Extra clearance with the 55QS29309A  Found these online, New for $21 each with pins and Free shipping.
By the way there are two different window crank handles.
https://www.bigmacktrucks.com/topic/63079-rw-door-handle/#findComment-454479
"A" denotes an engineering improvement to the original 55QS29309 part number (no "A"). And so would a "B", "C" and so forth. But it has no relationship with the standard R/U/DM applicable 55QS23.
And when there is no "P" variation in the part number, it is considered to be a P1 (e.g. 55QS29309AP1).
https://www.bigmacktrucks.com/topic/63079-rw-door-handle/#findComment-454491
