8 hours ago, fjh said:
Rd800? Maybe 18000 is a  heavy axle! Flat metal fenders?
Yup, got to find out more.  18 on the front and 38 on the rear???
15 hours ago, NLC said:
It has 18,000 front axle And 38,000 rears.
https://www.bigmacktrucks.com/topic/63081-r300-mack-dump/#findComment-454421
26 minutes ago, NLC said:
I got the information on this truck. It is a R686ST, has a 300 Mack motor, 6 speed Mack transmission, 4:17 rears. Would this combination be a good dump truck?
ST means it was built as a semi-tractor, probably has 10.5 or 12k front axle and 34k or 38k rears. Won't have the capacity of an RD or DM with heavier axles, but the 6 speed has a low hole which is good, will make a fine dump truck if it's in good shape and has enough capacity for your needs.
https://www.bigmacktrucks.com/topic/63081-r300-mack-dump/#findComment-455048
S means tandem drive axles
T means tractor trailer brake package
The ST does not mean it was ever a tractor.
Since Mack would build what ever the client requested so Maxidyne is just guessing what the specs are based on a generic model number.
To get the asbuilt specs you need to contact the Mack museum.
Keep in mind that this is at least a 30 year old truck that has probably been rebuilt and modified over its life so anything is possible now.
Your best bet is to look over the truck and figure out what axles, suspension and frame are currently there.
https://www.bigmacktrucks.com/topic/63081-r300-mack-dump/#findComment-455056
Seems most of the R685ST dump trucks I've seen were converted from tractors, which made sense because there were a lot of them and a dump truck would sell for a lot more than a used tractor. But it's entirely possibly that some tractors were converted to dumps before they even had a 5th wheel mounted on them. The opposite is certainly true- IIRC the Postal Service Macks often were noted as "MR688P" or "MR688S" with no "T" on the serial number plate but with Mack's full knowledge were delivered with 5th wheels and trailer connections.
https://www.bigmacktrucks.com/topic/63081-r300-mack-dump/#findComment-455065
I know of 19 RS685LST’s that the FS2, factory order form, lists them as straight trucks because they were ordered as dump trucks per Don Schumaker
I currently have a RS685LT that was never a tractor it has always been a flatbed
So thinking that a ST or any T that is currently a dump truck was converted from a tractor is incorrect
I remember picking up brand new Mack r models in the mid 80’s from the dealer and taking them to have there bed, box or roll off rails installed
https://www.bigmacktrucks.com/topic/63081-r300-mack-dump/#findComment-455110
Perhaps the customer(s) ordered them as tractors to get the shorter frame that didn't extend far behind the rear wheels so the body installer didn't have to cut off the frame overhang beyond the rear axles? Another possibility is that if a customer wanted air and electrical hookups for a pup trailer, maybe it was cheaper or easier to order a tractor and extend the lines to the rear of the frame?  And no doubt there were canceled orders for tractors that got dump bodies installed instead of fifth wheels when they were brand new. That said, there's ample evidence of a first life as tractors in thousands of Mack tractors now outfitted as dump trucks.
https://www.bigmacktrucks.com/topic/63081-r300-mack-dump/#findComment-455123
