Sometimes when I I press D it feels like truck is not going into gear. The lightning bolt comes on and once I press fuel pedal it goes into gear hard. Like as if there’s no clutch brake. Some times when hooked to lap top it says clutch slipping. After driving some time the lightning bolt goes out and it goes into gear normal and smooth. Also I cannot switch from N1 to N2 when lightning bolt is on.
12 speed
has anyone experienced this before?
thanks in advance
https://www.bigmacktrucks.com/topic/63319-2016-cxu613-auto-trans-acting-up/
Its likley the clutch actuator is leaking down and is not operating the clutch properly Either a leaking hose or  or the bellows has a hole!either way its pricey! and you likey have to take it to a dealer!
Edited by fjh
